[GRASS-dev] winGRASS compilation: perl not found (needed for MAN)
Markus Neteler
neteler at osgeo.org
Wed Jan 20 09:52:52 EST 2010
On Wed, Jan 20, 2010 at 12:16 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Back-porting is just a matter of copying g.html2man.py from 7.0 and
> changing HTML2MAN in man/Makefile (remove the "sh").
[and add the .py extension of course]
> Trying this, I get errors in 66 files, while 416 build without error.
> If parsing fails, g.html2man.py will display the line number and the
> line, but won't describe the error (most of them are due to using
> block-level elements as if they were inline; using blocks inside
> <dt>...</dt> is a common flaw).
I have reduced it to these errors here:
htmlmapdriver.html:63
wxGUI.html:154
wxGUI.Vector_Digitizing_Tool.html:210
Those are tricky <dd> issues (too tired now),
Markus
