[GRASS-dev] grass64 install for Mac
Helena Mitasova
hmitaso at unity.ncsu.edu
Sun Jan 24 23:55:12 EST 2010
Just a follow up on the Mac installation issues:
as I mentioned several users reported problems switching from tcltk GUI to wxGUI:
after running g.gui in all possible ways they kept getting an error message.
It turns out that the problem was missing FFTW3 library (on Leopard only?)
- after installing the correct version of FFTW3 everything runs fine.
Another most common problem was people forgetting to install Active Tcl
and then complaining that nviz keeps crashing. Or they thought that Active
Tcl is needed only for Tcltk GUI and when they are running wxpython GUI it is not needed.
Everything is written on the web site so there isn't really a problem as long as
the users read carefully the instructions (what nobody does these days).
As more OS versions and GRASS releases have been added to the web page
people simply overlook important issues.
So William and others on Mac, I am wondering whether it would help for future
to have the instructions for Snow Leopard written in a simpler way something like this
For Snow Leopard install:
- Unix Compatibility Frameworks: SQLite3, FreeType, UnixImageIO, PROJ, GEOS, and GDAL
- ActiveTcl 8.5 (not 8.6) from ActiveState
- GRASS.app 64
- sample data set from here: link
(I am not sure I have it right, but I assume that Python, wxPython and FFTW3
does not have to be installed separately)
For older Mac OS X versions I would keep it as is.
I am not sure that this is the best solution, others may have better ideas,
thank you,
Helena
