[GRASS-dev] Re: [GRASS GIS] #1032: ErrorCommandExecution g.proj
GRASS GIS trac at osgeo.org
Sun May 2 05:38:40 EDT 2010
  Reporter:  sallar   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  blocker  |   Milestone:  6.4.0
 Component:  default  |     Version:  6.4.0 RCs
Resolution:           |    Keywords:  g.proj
  Platform:  Linux    |         Cpu:  x86-32
Comment (by sallar):
 Hi, I rebuilded whitout optimization and stripping but the result is the
 same.
 I get this by gdb:
 GRASS 6.4.0RC6 (PIT):~ > gdb g.proj
 GNU gdb 6.8-debian
 Copyright (C) 2008 Free Software Foundation, Inc.
 License GPLv3+: GNU GPL version 3 or later
 <http://gnu.org/licenses/gpl.html>
 This is free software: you are free to change and redistribute it.
 There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
 and "show warranty" for details.
 This GDB was configured as "i486-linux-gnu"...
 then run -p:
 (gdb) run -p
 Starting program: /usr/local/grass-6.4.0RC6/bin/g.proj -p
 [Thread debugging using libthread_db enabled]
 D2/5: G__read_Cell_head
 D2/5: G__read_Cell_head_array
 D3/5: region item: proj:       0
 D3/5: region item: zone:       0
 D3/5: region item: north:      4526334.08251007
 D3/5: region item: south:      4474101.25111007
 D3/5: region item: east:       563815.12526504
 D3/5: region item: west:       528349.01576504
 D3/5: region item: cols:       20
 D3/5: region item: rows:       20
 D3/5: region item: e-w resol:  1773.305475
 D3/5: region item: n-s resol:  2611.64157
 D3/5: region item: top:        1
 D3/5: region item: bottom:     0
 D3/5: region item: cols3:      20
 D3/5: region item: rows3:      20
 D3/5: region item: depths:     1
 D3/5: region item: e-w resol3: 1773.305475
 D3/5: region item: n-s resol3: 2611.64157
 D3/5: region item: t-b resol:  1
 XY location (unprojected)
 *** glibc detected *** /usr/local/grass-6.4.0RC6/bin/g.proj: double free
 or corruption (fasttop): 0x0804f510 ***
 [New Thread 0xb6dff6d0 (LWP 19967)]
 ======= Backtrace: =========
 /lib/i686/cmov/libc.so.6[0xb77fe624]
 /lib/i686/cmov/libc.so.6(cfree+0x96)[0xb7800826]
 /usr/lib/libstdc++.so.6(_ZdlPv+0x21)[0xb747c2e1]
 /usr/lib/libstdc++.so.6(_ZNSs4_Rep10_M_destroyERKSaIcE+0x1d)[0xb7458b2d]
 /usr/lib/libstdc++.so.6(_ZNSsD1Ev+0x51)[0xb745a501]
 /lib/i686/cmov/libc.so.6(__cxa_finalize+0xc1)[0xb77bee51]
 /usr/lib/libgeos-3.1.0.so[0xb72d0dc4]
 /usr/lib/libgeos-3.1.0.so[0xb7379cd0]
 /lib/ld-linux.so.2[0xb7f0c453]
 /lib/i686/cmov/libc.so.6(exit+0x89)[0xb77beab9]
 /usr/local/grass-6.4.0RC6/bin/g.proj(print_projinfo+0x0)[0x804abec]
 /lib/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb77a6455]
 /usr/local/grass-6.4.0RC6/bin/g.proj[0x80499f1]
 ======= Memory map: ========
 08048000-0804d000 r-xp 00000000 03:03 1195911
 0804d000-0804e000 rw-p 00004000 03:03 1195911
 0804e000-0806f000 rw-p 0804e000 00:00 0          [heap]
 b6c00000-b6c21000 rw-p b6c00000 00:00 0
 b6c21000-b6d00000 ---p b6c21000 00:00 0
 b6dff000-b6e02000 rw-p b6dff000 00:00 0
 b6e02000-b6e68000 r-xp 00000000 03:03 819183
 /usr/lib/libgcrypt.so.11.4.4
 b6e68000-b6e6a000 rw-p 00066000 03:03 819183
 b6e6a000-b6e6d000 r-xp 00000000 03:03 818510     /usr/lib/libgpg-
 error.so.0.3.0
 b6e6d000-b6e6e000 rw-p 00002000 03:03 818510     /usr/lib/libgpg-
 error.so.0.3.0
 b6e6e000-b6e7d000 r-xp 00000000 03:03 818452
 /usr/lib/libtasn1.so.3.0.15
 b6e7d000-b6e7e000 rw-p 0000e000 03:03 818452
 b6e7e000-b6f15000 r-xp 00000000 03:03 818764
 /usr/lib/libgnutls.so.26.4.6
 b6f15000-b6f1b000 rw-p 00097000 03:03 818764
 b6f1b000-b6f1c000 rw-p b6f1b000 00:00 0
 b6f1c000-b6f32000 r-xp 00000000 03:03 817192
 /usr/lib/libsasl2.so.2.0.22
 b6f32000-b6f33000 rw-p 00015000 03:03 817192
 b6f33000-b6f3f000 r-xp 00000000 03:03 817395
 /usr/lib/liblber-2.4.so.2.1.0
 b6f3f000-b6f40000 rw-p 0000c000 03:03 817395
 b6f40000-b6f50000 r-xp 00000000 03:03 51464
 /lib/i686/cmov/libresolv-2.7.so
 b6f50000-b6f52000 rw-p 0000f000 03:03 51464
 b6f52000-b6f54000 rw-p b6f52000 00:00 0
 b6f54000-b6f56000 r-xp 00000000 03:03 32806      /lib/libkeyutils-1.2.so
 b6f56000-b6f57000 rw-p 00001000 03:03 32806      /lib/libkeyutils-1.2.so
 b6f57000-b6f5e000 r-xp 00000000 03:03 277584
 /usr/lib/libkrb5support.so.0.1
 b6f5e000-b6f5f000 rw-p 00006000 03:03 277584
 b6f5f000-b6f60000 rw-p b6f5f000 00:00 0
 b6f60000-b6f83000 r-xp 00000000 03:03 277557
 /usr/lib/libk5crypto.so.3.1
 b6f83000-b6f84000 rw-p 00023000 03:03 277557
 b6f84000-b6f99000 r-xp 00000000 03:03 51453
 /lib/i686/cmov/libpthread-2.7.so
 b6f99000-b6f9b000 rw-p 00014000 03:03 51453
 b6f9b000-b6f9d000 rw-p b6f9b000 00:00 0
 b6f9d000-b6fdd000 r-xp 00000000 03:03 817426
 /usr/lib/libldap_r-2.4.so.2.1.0
 b6fdd000-b6fdf000 rw-p 0003f000 03:03 817426
 b6fdf000-b6fe0000 rw-p b6fdf000 00:00 0
 b6fe0000-b6fe9000 r-xp 00000000 03:03 50035
 /lib/i686/cmov/libcrypt-2.7.so
 b6fe9000-b6feb000 rw-p 00008000 03:03 50035
 b6feb000-b7012000 rw-p b6feb000 00:00 0
 b7012000-b703b000 r-xp 00000000 03:03 277569
 /usr/lib/libgssapi_krb5.so.2.2
 b703b000-b703c000 rw-p 00028000 03:03 277569
 b703c000-b703d000 rw-p b703c000 00:00 0
 b703d000-b703f000 r-xp 00000000 03:03 32652      /lib/libcom_err.so.2.1
 b703f000-b7040000 rw-p 00001000 03:03 32652      /lib/libcom_err.so.2.1
 b7040000-b70d2000 r-xp 00000000 03:03 277457     /usr/lib/libkrb5.so.3.3
 b70d2000-b70d4000 rw-p 00092000 03:03 277457     /usr/lib/libkrb5.so.3.3
 b70d4000-b720e000 r-xp 00000000 03:03 1354596
 /usr/lib/i686/cmov/libcrypto.so.0.9.8
 b720e000-b7224000 rw-p 0013a000 03:03 1354596
 b7224000-b7227000
 Program received signal SIGABRT, Aborted.
 [Switching to Thread 0xb6dff6d0 (LWP 19967)]
 0xb7efd424 in __kernel_vsyscall ()
 and bt full:
 (gdb) bt full
 #0  0xb7efd424 in __kernel_vsyscall ()
 No symbol table info available.
 #1  0xb77bb640 in raise () from /lib/i686/cmov/libc.so.6
 #2  0xb77bd018 in abort () from /lib/i686/cmov/libc.so.6
 #3  0xb77f834d in ?? () from /lib/i686/cmov/libc.so.6
 #4  0x00000005 in ?? ()
 #5  0xbfffd0bc in ?? ()
 #6  0x00000400 in ?? ()
 #7  0x6f736572 in ?? ()
 #8  0x20203a6c in ?? ()
 #9  0xb78ce648 in ?? () from /lib/i686/cmov/libc.so.6
 #10 0x00000017 in ?? ()
 #11 0xbffff9de in ?? ()
 #12 0x00000024 in ?? ()
 #13 0xb78ce661 in ?? () from /lib/i686/cmov/libc.so.6
 #14 0x00000002 in ?? ()
 #15 0xb78ce6dc in ?? () from /lib/i686/cmov/libc.so.6
 #16 0x00000023 in ?? ()
 #17 0xb78ce665 in ?? () from /lib/i686/cmov/libc.so.6
 #18 0x00000004 in ?? ()
 #19 0xbfffd5eb in ?? ()
 #20 0x00000008 in ?? ()
 #21 0xb78ce66b in ?? () from /lib/i686/cmov/libc.so.6
 #22 0x00000005 in ?? ()
 #23 0xb7ea1a6e in ?? () from /usr/local/grass-6.4.0RC6/lib/libgrass_gis.so
 #24 0xb779ca8c in ?? () from /lib/i686/cmov/libc.so.6
 #25 0xb78ce66b in ?? () from /lib/i686/cmov/libc.so.6
 #26 0x00000005 in ?? ()
 #27 0xbfffcff0 in ?? ()
 #28 0xb77f81a1 in ?? () from /lib/i686/cmov/libc.so.6
 #29 0xb78ce66c in ?? () from /lib/i686/cmov/libc.so.6
 #30 0x00000025 in ?? ()
 #31 0xb7f075cf in ?? () from /lib/ld-linux.so.2
 #32 0xb77fe624 in ?? () from /lib/i686/cmov/libc.so.6
 #33 0x00000002 in ?? ()
 #34 0xb78ce648 in ?? () from /lib/i686/cmov/libc.so.6
 #35 0xbffff9de in ?? ()
 #36 0xb78ce6dc in ?? () from /lib/i686/cmov/libc.so.6
 #37 0xbfffd5eb in ?? ()
 #38 0xb78ce6dc in ?? () from /lib/i686/cmov/libc.so.6
 #39 0x30ffd628 in ?? ()
 #40 0x66343038 in ?? ()
 #41 0x00303135 in ?? ()
 #42 0xb78e6ff4 in ?? () from /lib/i686/cmov/libc.so.6
 #43 0xb78e8160 in ?? () from /lib/i686/cmov/libc.so.6
 #44 0x0804f510 in ?? ()
 #45 0xbfffd620 in ?? ()
 #46 0xb7800826 in free () from /lib/i686/cmov/libc.so.6
 Backtrace stopped: frame did not save the PC
 thanks!
Ticket URL: <http://trac.osgeo.org/grass/ticket/1032#comment:13>
