[GRASS-dev] wxvdigit
Mohammed Rashad
mohammedrashadkm at gmail.com
Wed Sep 29 11:23:58 EDT 2010
ok. I am building a grass standalone application. As a part of it I need
vector digitizer. My application is written in C++ and cannot use python for
some other reasons.
i saw the code gui/wxpython/vdigit. that are nice c++ classes.
Can I compile then with wxwidgets(C++) library and use it as a vector
digitizer based on wxwidgets.
There are wxwidgets specific code. so i thought of rewriting
wxpython/gui_modules/vdigit.py
and make a vector digitizer .
Is that possible.?
I need help in creating wxvidgit.so file. Will you please tell the steps to
make vedit library..
On Wed, Sep 29, 2010 at 6:46 PM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2010/9/29 Mohammed Rashad <mohammedrashadkm at gmail.com>:
> > All I need is create an map with one point from a c++ program which is
> > linked to _grass6_wxvdigit.so located in
> > /usr/local/grass-6.5.svn/etc/wxpython/vdigit.
> > How to access the functions of the library using a C++ program run from
> > grass shell with all variables set. My program renders a map when run
> from
> > grass shell. Now I want to add
> use vedit library as I suggested (take a look at vector/v.edit and
> gui/wxpython/vdigit for implementation issues). Also note that vector
> digitizer is going to be rewritten from C++ to Python. So don't waste
> your time with gui/wxpython/vdigit component.
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Rashad
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100929/89405477/attachment.html
