[GRASS-dev] Bad map deletion beahviour with external OGR sources
Martin Landa
landa.martin at gmail.com
Fri Jan 14 11:01:34 EST 2011
2011/1/14 Benjamin Ducke <benjamin.ducke at oxfordarch.co.uk>:
> I Think I found a problem with OGR datasources linked
> in using v.external.
> If I change into a directory with shapefiles and then
> issue the following to link in the data in "myShapefile.shp":
> v.external dsn=. layer=myShapefile output=linked_in
> And then change into another directory and issue any command
> that wants to work on "linked_in", e.g.:
> g.remove vect=linked_in
> v.info linked_in
> I get:
> ERROR: Cannot open layer 'myShapefile'
> But when I change back into the directoy where I used
> to be when running the v.external command, it works.
> So I think v.external should take care to always link
> to the absolute location of the source in the file
> system (if I specify "dsn=" as an absolute path,
> things work fine).
at least it should print a warning. Please report it on trac. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
