[GRASS-dev] GSOC Week 3 report : Adding WMS layer support to update WXGUI
Sudeep Singh sudeep495 at gmail.com
Mon Jun 20 08:42:04 EDT 2011
Hi Hamish,
Thanks for the info. Yes, as for now it doesn't seems to be too complicated.
Regards
Sudeep
On Fri, Jun 17, 2011 at 9:50 PM, Hamish <hamish_b at yahoo.com> wrote:
> Sudeep Singh wrote:
> > Hi all,
> > This is my 3rd week report. Please find it at following link.
> http://grass.osgeo.org/wiki/WxGUI_WMS_service_rendering_GSoC_2011#Report_.233_9-06-2011
> > thanks
> Hi Sudeep,
> as you get more into the coding of the WMS parts, I guess you
> have seen the specification docs for it:
>    http://www.opengeospatial.org/specs/?page=specs
>    http://www.opengeospatial.org/standards/wms
> [hmrf, the spec now seems to live behind some legalese-click-
> through. I have an old copy which did not require that, if you
> don't like to agree to those things]
> see also links at
>  http://live.osgeo.org/en/standards/wms_overview.html
> the QGIS and GDAL implementations are probably easier examples,
> but see also the old scripts/r.in.wms/ in the GRASS source code.
> (I would not suggest to use that as a model for your work, the
> design is a bit convoluted) Maybe the python version of r.in.wms
> in grass7 source code is not as complicated?
> best,
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110620/ffb3761a/attachment-0001.html
