[GRASS-dev] GRASS7 ImageryLib
Markus Metz
markus.metz.giswork at gmail.com
Sat Dec 8 12:21:52 PST 2012
[answering here because I have worked on some of the affected modules]
On Wed, Dec 5, 2012 at 6:16 PM, Mohammed Rashad
<mohammedrashadkm at gmail.com> wrote:
> On Fri, Nov 30, 2012 at 7:46 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Fri, Nov 30, 2012 at 5:26 AM, Mohammed Rashad
>> > All,
>> > I found these here[1] and says many things which needed help. So I
>> > thought
>> > to give a try in order
>> > 1. Imagery Library needs fundamental clean up (the library is not
>> > maintained
>> > from GRASS 5)
>> > Anyone can elaborate on this line?
>> Fully agreed.
>> It might be sensible to merge the various image libraries:
>> GRASS 6/7:
>> * lib/imagery/: standard lib, in use (i.* except for i.points3,
>> i.rectify3, see below)
>> * imagery/i.ortho.photo/libes/: standard lib, in use (i.ortho.photo,
>> photo.*)
> i.points3 and i.rectify3 doesnt uses standard lib. So adding API style code
> which can be used by i.point3 and i.rectify3 is what you are saying. Am I
> correct?
I guess so, but I would suggest to move the libs needed by i.points3
and i.rectify3 to a separate GRASS lib, probably ortholib
> i.ortho.photo uses i.ortho.photo/libes right?
No, it uses (will use) ortholib, currently i.ortho.photo/lib, but I am
busy porting it and related modules to trunk.
> so merging both libs will provide an API which any grass imagery module can
> share right?
I would suggest to separate standard imagery lib and
orthorectification, because these two use substantially different
algorithms. The ortholib depends on imager lib.
>> GRASS 5 (! only) image3 lib:
>> * libes/image3/: never finished improvement which integrated the
>> standard lib and the ortho lib. Seems to provide also ortho
>> rectification for satellite data (i.points3, i.rectify3)
>> GRASS 5/6 image proc commands:
>> * merge of i.points, i.vpoints, i.points3 (see above)
>> * merge of i.rectify and i.rectify3 (see above)
>> Overall
>> * add other warping methods (maybe lanczos or thin splines from GDAL?)
> This part is not clear to me at all
Lanczos is already available.
What could be gained by adding thin splines to the existing bilinear,
bicubic, bspline, lanczos methods?
Markus M
>> However, the library cleanup in GRASS 7 would be essential.
>> > 2. Reimplement groups to be generic element (in GIS Library)
>> > I guess i.group module should be g.group which can groups both
>> > raster/vector
>> > maps
>> > Is that correct?
>> Correct I don't know, maybe subject to discussion.
> Anyone have any comments ?
>> Best
>> Markus
> Regards,
> Rashad
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
