[GRASS-dev] Extending r.colors to support multiple maps
Sören Gebbert
soerengebbert at googlemail.com
Thu Nov 1 11:31:36 PDT 2012
Dear all,
i have committed (r53640) the patch to implement multiple raster/3D raster
support in r.colors, since there were no objections against my
modification. :)
I have committed (r53641) a new temporal module (t.rast.colors) in addition
to the modification of r.colors to create a color table for all maps in a
space time raster dataset.
Best regards
Soeren
2012/10/30 Sören Gebbert <soerengebbert at googlemail.com>
> Dear all,
> i have attached a patch that extents r.colors to support multiple maps
> as input.
> The idea is that each map gets the same color table attached that is
> computed based on the range and cell statistics of all input maps.
> This is IMHO very meaningful in case of time series data.
> The patch provides full backward compatibility. Multiple maps can be
> provided
> as comma separated map list or as an input file with one map name per line.
> Please have a look at the patch.
> I would like to apply the it as well as tests in case there are no
> objections against.
> Best regards
> Soeren
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121101/4e783167/attachment.html>
