[GRASS-dev] [GRASS GIS] #1239: wxGUI command layer broken and unusable
trac at osgeo.org
Thu Nov 1 20:49:25 PDT 2012
Reporter: garu | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.3 RCs
Keywords: layer manager | Platform: MSWindows XP
Cpu: Unspecified |
Changes (by cmbarton):
* version: 6.4.0 => 6.4.3 RCs
Comment:
I just tried the command layer again and it is still unusable.
It doesn't work at all if it is the only layer. But if another layer is
added, they you can type a command into it if you make the layer manager
window big enough.
The problem is that you cannot see the command at all. I might be useful
in some cases (I had a use for it to try a d.vect.chart that also has a
problem from its GUI), but not if you cannot type into it or see what you
have typed when you do type into it.
It needs to be fixed or removed before the 6.4.3 release.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1239#comment:11>
