[GRASS-dev] r.modis in GRASS 7 trunk
Yann Chemin
yann.chemin at gmail.com
Sat Nov 3 01:45:02 PDT 2012
On 2 November 2012 22:35, Glynn Clements <glynn at gclements.plus.com> wrote:
> Yann Chemin wrote:
> > > r53636 fixes a couple of issues with the r.in.wms2 and v.in.wfs2
> > > Makefiles. From the add-ons/grass7 directory, you can do e.g.:
> > > make MODULE_TOPDIR=$GISBASE
> > Thanks, including addons SVN in my daily compile... How could we
> auto-load
> > those additional modules in their GUI menu groups?
> AFAIK, at present you need to edit menudata.xml.
OK, I will see how to modify this one
> > > to build everything using the include/Make/*.make files from GRASS
> > > 7 (either installed or the dist.<arch> directory).
> > > imagery/i.vi.mpi requires mpicc. This should probably be a separate
> > > variable, e.g. $(MPICC).
> > to be set as a configure file option?
> Once it's moved into trunk, configure checks should be added. Until
> then, it should just define a variable which can be overridden on the
> command line.
> Currently, it uses CC, which is problematic. Uusing CC=mpicc on the
> command line would cause all C code to be compiled using mpicc, while
> using e.g. CC=gcc on the command line would override the setting in
> i.vi.mpi/Makefile.
> A fundamental property of "make" is that variables set on the command
> line override settings within a Makefile, so every Makefile variable
> is effectively a command-line parameter with a default value.
Thank you for this insight Glynn
Yann Chemin
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121103/2d946c50/attachment.html>
