[GRASS-dev] NVIZ crash info
Michael Barton
Michael.Barton at asu.edu
Wed Oct 17 21:29:04 PDT 2012
Here is some additional info on the NVIZ crash.
In the current version of GRASS, I can display a horizontal slice. BUT if I go to change the configuration of the slice (reduce it in the horizontal x or y direction or change the tilt), it crashes the GUI.
Trying to display a vertical slice or isosurface crashes the display.
In r48000 (and maybe in r50000 too), I can display a horizontal or vertical slice and manipulate its position. However, attempting to display an isosurface will crash the GUI.
I want to try r47000, but have not had a chance yet.
But the problem seems to be getting worse over the past year--worked OK about 15 months ago, partly worked 12 months ago, does not work by 3 months ago and maybe earlier.
I tried compiling without building for OSX 10.6 (OSX 10.8 and python 12.7) and it is just as bad. I have not tried building for a single architecture (32 or 64 bit) yet.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Oct 17, 2012, at 3:17 PM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> I just tried grass7 binary compiled by Michael and the isosurfaces
> indeed crash the gui. The attached screenshot shows the error message.
> I did not have time to compile 6.4.3 and 7 on MasOSX 10.7.5 myself yet,
> but as I mentioned before I have the isosurfaces running in GRASS7
> compiled in august on 10.6 .
> Helena
> Also, When switching to 3d for the first time I get and error, but it
> ran after switching to 2d and 3d again:
> Starting 3D view mode...
> Traceback (most recent call last):
> File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc
> /gui/wxpython/mapdisp/toolbars.py", line 231, in
> OnSelectTool
> self.parent.AddNviz()
> /gui/wxpython/mapdisp/frame.py", line 299, in AddNviz
> Map = self.Map, tree = self.tree, lmgr = self._layerManager)
> /gui/wxpython/nviz/mapwindow.py", line 154, in __init__
> self.decoration['arrow']['size'] = self._getDecorationSize()
> /gui/wxpython/nviz/mapwindow.py", line 1177, in
> _getDecorationSize
> size = self._display.GetLongDim() / 8.
> AttributeError
> 'NoneType' object has no attribute 'GetLongDim'
> On Wed, Oct 17, 2012 at 3:09 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> This seems like a good idea. Gives us time to think about the value and costs of using and bundling dateutil.
>> Michael Barton
>> School of Human Evolution &Social Change
>> ...Sent from my iPad
>> On Oct 17, 2012, at 11:34 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
>>> On 17/10/12 13:21, Sören Gebbert wrote:
>>>> Hi Michael,
>>>> sorry to introduce something painful as a python-dateutil dependency.
>>>> My fault. I should have discussed this on the list indeed.
>>>> I have completely removed the dateutil dependency from the temporal
>>>> GIS in r53435. For now
>>>> only two types of calendar time stings are supported for parsing.
>>> Do you really have to remove it completely ? Can't you check for its presence and if not present fall back on the basic date version ? And put a hint in the manuals about its installation being strongly recommended ?
>>> Moritz
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Helena Mitasova
> Associate Professor
> Department of Marine, Earth and Atmospheric Sciences
> North Carolina State University
> 1125 Jordan Hall
> NCSU Box 8208
> Raleigh, NC 27695-8208
> http://skagit.meas.ncsu.edu/~helena/
> email: hmitaso at ncsu.edu
> ph: 919-513-1327 (no voicemail)
> fax 919 515-7802
> <grass7voxelcrash.png>
