[GRASS-dev] Can't add vector label and point file in cartiographic composer
Anna Kratochvílová
kratochanna at gmail.com
Mon Apr 22 13:40:11 PDT 2013
On Sat, Apr 20, 2013 at 10:28 AM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
> Hi all,
> I Can't add vector label and point file in cartiographic composer. But this
> is very much necessary in my project. I use grass6.5.
Please see my recent answer [1] related to vector labels. With point
file you mean vector map with points? Add vector map layer -> select
map and choose data type points -> click button add -> optionally
click on properties to set the appearance of the vector map.
Anna
[1] http://lists.osgeo.org/pipermail/grass-user/2013-April/067902.html
> Please give me a solution.
> Thanks & Rgards,
> Swapan Ghosh
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
