[GRASS-dev] Can't add vector label and point file in cartiographic composer
SWAPAN GHOSH swap.ghsh at gmail.com
Tue Apr 23 04:02:08 PDT 2013
Thank you very much Anna. Please add the label to carteographic composer as
soon as possible.
Thanks,
Swapan
On Tue, Apr 23, 2013 at 2:10 AM, Anna Kratochvílová
<kratochanna at gmail.com>wrote:
> On Sat, Apr 20, 2013 at 10:28 AM, SWAPAN GHOSH <swap.ghsh at gmail.com>
> wrote:
> > Hi all,
> > I Can't add vector label and point file in cartiographic composer. But
> this
> > is very much necessary in my project. I use grass6.5.
> Please see my recent answer [1] related to vector labels. With point
> file you mean vector map with points? Add vector map layer -> select
> map and choose data type points -> click button add -> optionally
> click on properties to set the appearance of the vector map.
> Anna
> [1] http://lists.osgeo.org/pipermail/grass-user/2013-April/067902.html
> > Please give me a solution.
> > Thanks & Rgards,
> > Swapan Ghosh
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130423/5a370f57/attachment.html>
