[GRASS-dev] Can't add vector label and point file in cartiographic composer
Anna Kratochvílová
kratochanna at gmail.com
Wed Apr 24 12:10:11 PDT 2013
On Tue, Apr 23, 2013 at 1:02 PM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
> Thank you very much Anna. Please add the label to carteographic composer as
> soon as possible.
I just added labels support to Cartographic composer in grass 7 (Add
overlays -> Add labels)
Anna
> Thanks,
> Swapan
> On Tue, Apr 23, 2013 at 2:10 AM, Anna Kratochvílová <kratochanna at gmail.com>
> wrote:
>> On Sat, Apr 20, 2013 at 10:28 AM, SWAPAN GHOSH <swap.ghsh at gmail.com>
>> wrote:
>> > Hi all,
>> > I Can't add vector label and point file in cartiographic composer. But
>> > this
>> > is very much necessary in my project. I use grass6.5.
>> Please see my recent answer [1] related to vector labels. With point
>> file you mean vector map with points? Add vector map layer -> select
>> map and choose data type points -> click button add -> optionally
>> click on properties to set the appearance of the vector map.
>> Anna
>> [1] http://lists.osgeo.org/pipermail/grass-user/2013-April/067902.html
>> > Please give me a solution.
>> > Thanks & Rgards,
>> > Swapan Ghosh
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
