[GRASS-dev] reg i.pca module
Rashad M mohammedrashadkm at gmail.com
Wed Feb 6 21:31:11 PST 2013
Hi
As mentioned in wiki does the output pixel = eigenvector * input pixel?
On Thu, Feb 7, 2013 at 10:59 AM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> Thanks Nikos and Mortiz,
> From GRASS Wiki what I got is I need more details of step.6 in the
> Background section
> i.e *project original dataset signals* (PC's or PC scores: eigenvector *
> input-data) to get
> projecting the dataset is based on the text output of i.pca eigen values
> and input data.
> I guess there must be a simple transformation equation that can be applied
> to every pixel in the input data to get the raster output of i.pca.
> Nikos, Your thesis is a long read and I only need a very small part from
> it. If you could tell me those( I strongly believe you can ) then it will
> be great. I need to start coding after this and this is only a small part
> of it. my actual work is pure pixel identification for spectral unmixing
> On Thu, Feb 7, 2013 at 5:43 AM, Nikos Alexandris <nik at nikosalexandris.net>wrote:
>> Rashad M wrote:
>> > > Hi All,
>> > > i.pca outputs raster bands and the pixel values are transformed
>> > > obivously. But anyone can tell me how the transformation works
>> > > if a pixel P1 has value X after i.pca it will be Y
>> > > Is there any specific math equation that is applied to every pixel by
>> PCA?
>> Moritz Lennert wrote:
>> > http://en.wikipedia.org/wiki/Principal_component_analysis
>> > and
>> > http://grasswiki.osgeo.org/wiki/Principal_Component_Analysis
>> Ehm, right --  I've overlooked your post Moritz, apologies.
>> Nikos
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130207/fbb66678/attachment.html>
