[GRASS-dev] Python handling in winGRASS7 [was: Re: GRASS GIS 7 tech-preview release preparations]
Moritz Lennert mlennert at club.worldonline.be
Fri Jul 26 03:14:49 PDT 2013
On 26/07/13 11:40, Helmut Kudrnovsky wrote:
> hi,
> On 26/07/13 00:04, Helmut Kudrnovsky wrote:
>> Would it be a possible option to implement only a)
> there is already a bundled/embedded python in standalone WinGRASS6/7 and
> OSGeo4w-WinGRASS6/7.
Yes, so this should be reformulated as "keep the current option of
bundling an embedded python".
However, again within the limits of my understanding, aren't the issues of
- calling a script from a script
and
- making addons easily callable
linked to the question of system-wide vs embedded Python ?
IIUC, in order to solve (at least) the first issue, you have to make
python code callable and executable without the .py extension, using
assoc .py=Python.File
and
ftype Python.File=C:\Path\to\pythonw.exe "%1" %*
but as the ftype setting is system wide, you can't just hijack all
python scripts on a machine to use the Python interpreter embedded in GRASS;
I'm really not expert enough on these issues, so some input from the
gurus would help, here.
> some more issues related to WinGRASS and python are mentioned also in
> http://trac.osgeo.org/grass/ticket/2015
I didn't see this yesterday while experimenting with a fresh install on
WinXP without system-wide Python installed. I'll try again with a
system-wide Python installed to see if that makes any difference.
Moritz
