[GRASS-dev] GRASS 6.4.3 release planning
Helmut Kudrnovsky
hellik at web.de
Tue Jun 4 13:52:51 PDT 2013
IMHO it's time GRASS 6.4.3 should go out into the wild...
>#1967: wxPy loc'n wiz: doesn't allow ellipsoid without datum
> --both now in svn, please help test the local projections you know.
> You need to check the final result, not just the wizard Summary.
> If the location setup terms are bad from offset, we break people's
> data silently, ... ouch, first impression of the software too in
> case it tracebacks.
> --please everyone help test, bad new location def'ns mean
> all the work that happens after is also broken--
some teste here
http://lists.osgeo.org/pipermail/grass-user/2013-May/068240.html
http://lists.osgeo.org/pipermail/grass-user/2013-May/068241.html
http://lists.osgeo.org/pipermail/grass-user/2013-May/068242.html
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-6-4-3-release-planning-tp4995930p5057930.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
