[GRASS-dev] grass, python, Pygrass
Ivan Marchesini
ivan.marchesini at gmail.com
Tue Jun 25 21:40:59 PDT 2013
Dear grass-developers
I'm working with Python, GRASS and Pygrass and I have some small
problems probably due to my poor knowledge of Python.
I would ask your help.
I have this small code:
grass.run_command("v.to.rast", input=ocs, type="line", output="tmp_ocs", use="val", overwrite=True)
grass.mapcalc("$outmap = $a", a = dtm, outmap="demcut", overwrite = true)
grass.run_command("g.remove", rast="visitati")
np_ocs = raster.RasterNumpy("tmp_ocs")
np_ocs.open()
visited=np_ocs*0
visited.open()
for i in range(1,new.shape[0]-1):
for j in range(1,new.shape[1]-1):
if np_ocs[i,j] == 1:
visited[i,j] = 1
else:
visited[i,j] = 3
visited.name='visitati'
visited.close()
sys.exit("stop")
When I run it I obtain a lot of:
WARNING: rast=visitati,visitati: files could be the same, no rename
possible
I cannot understand where the warnings arise... and why..
can you help me??
many thanks
Ivan
