[GRASS-dev] [GRASS GIS] #1889: wxPy loc'n wiz: don't auto-launch into PERMANENT
GRASS GIS trac at osgeo.org
Sun Mar 10 00:11:22 PST 2013
 Reporter:  hamish           |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  blocker          |   Milestone:  6.4.3
Component:  wxGUI            |     Version:  6.4.3 RCs
 Keywords:  location wizard  |    Platform:  Unspecified
      Cpu:  x86-64           |
Comment(by annakrat):
 Replying to [comment:14 hamish]:
 > Hi,
 > just tested with a fresh build of relbr64. After setting the region
 bounds it is still printing some g.region debug output to the terminal.
 There is flag p in the g.region command
 ([http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/dialogs.py#L475
 here]). Intention?
 > when the create new mapset gui pops up, it would be good to have a few
 sentence tooltip available explaining what MAPSET means, and a [Help]
 button at the bottom that opened up $GISBASE/docs/html/helptext.html.
 Help button added in r55297. Please could you add the help text (I
 wouldn't use tooltip, just add another sentence to the message)?
 > > closing the ticket?
 > not before it has been ported to all branches. (please don't do
 development work in the release branch and then not sync with the dev
 branches. The release branch must be treated with great care, only code
 tested in the relevant dev branch should be backported to the release
 branch- by backporting it to the release branch you're personally signing
 off that the code is tested and works. tx)
 Sure, I just wanted to  wait for all the changes.
 Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1889#comment:15>
