[GRASS-dev] Problem deleting raster created from point file using v.to.rast
SWAPAN GHOSH
swap.ghsh at gmail.com
Mon Mar 11 00:53:06 PDT 2013
no error will not occur for deleting other raster.
I use here grass6.5
regards,
swapan
On Mon, Mar 11, 2013 at 12:15 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> I understand that from the command v.to.rast. what I asked is do you have
> problem deleting raster map "created" from v.to.rast or other raster maps.
> If you have problem deleting any raster map(create a duplicate and dont try
> with your actual data) then it this is an issue with g.remove.
> I want to make sure that first
> Also you didnt said about your grass version and platform yet.
> I tried v.to.rast on spearfish dataset and here is the output
> I copied archsites vector data as a backup.
> g.copy vect=archsites,arch2
> v.to.rast input=arch2 at PERMANENT output=temp use=cat
> Reading features...
> 100%
> Writing raster map...
> 100%
> Converted points/lines: 25 of 25
> v.to.rast complete.
> GRASS 7.0.svn (spearfish60):~ >
> g.remove temp at PERMANENT
> Removing raster <temp at PERMANENT>
> Btw, I am using GRASS7.0 (SVN 55285) on Ubuntu 12.04
> On Mon, Mar 11, 2013 at 11:55 AM, SWAPAN GHOSH <swap.ghsh at gmail.com>wrote:
>> No, I am just creating new raster from point vector map......
>> v.to.rast --overwrite input=Temp_Aug_86 at PERMANENT type=point
>> output=Rast_Temp_Aug_86 column=Rain14
>> here Temp_Aug_86 is point vector
>> but the problem is solve when we use command like-
>> output=Rast_Temp_Aug_86 column=Rain14 labelcolumn=cat
>> Regards
>> Swapan
>> On Sun, Mar 10, 2013 at 2:51 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>>> Does this error comes in deleting other maps. Could you try g.copy
>>> rast=old,new
>>> and delete the newly created raster map.
>>> Btw, Please tell your grass version and platform
>>> On Sun, Mar 10, 2013 at 1:41 PM, SWAPAN GHOSH <swap.ghsh at gmail.com>wrote:
>>>> *Dear all,*
>>>> I am using the command like-
>>>> Rast_Temp_Aug_86 at PERMANENT is created successfully.
>>>> But when I want to delete this raster using command like-
>>>> g.remove rast=Rast_Temp_Aug_86 at PERMANENT
>>>> Then I get an error like below-
>>>> *Removing raster <Rast_Temp_Aug_86 at PERMANENT>
>>>> fcell: couldn't be removed*
>>>> I am also trying this by running " g.remove -f
>>>> rast=Rast_Temp_Aug_86 at PERMANENT " but same problem arises.
>>>> Please give me some solution to recover this problem.
>>>> *Thanks & Regards,
>>>> Swapan*
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>>> Regards,
>>> Rashad
> Regards,
> Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130311/fbb53b45/attachment.html>
