[GRASS-dev] Problem deleting raster created from point file using v.to.rast
Rashad M mohammedrashadkm at gmail.com
Sun Mar 10 23:45:58 PDT 2013
I understand that from the command v.to.rast. what I asked is do you have
problem deleting raster map "created" from v.to.rast or other raster maps.
If you have problem deleting any raster map(create a duplicate and dont try
with your actual data) then it this is an issue with g.remove.
I want to make sure that first
Also you didnt said about your grass version and platform yet.
I tried v.to.rast on spearfish dataset and here is the output
I copied archsites vector data as a backup.
g.copy vect=archsites,arch2
v.to.rast input=arch2 at PERMANENT output=temp use=cat
Reading features...
 100%
Writing raster map...
 100%
Converted points/lines: 25 of 25
v.to.rast complete.
GRASS 7.0.svn (spearfish60):~ >
 g.remove temp at PERMANENT
Removing raster <temp at PERMANENT>
Btw, I am using GRASS7.0 (SVN 55285) on Ubuntu 12.04
On Mon, Mar 11, 2013 at 11:55 AM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
> No, I am just creating new raster from point vector map......
>  v.to.rast --overwrite input=Temp_Aug_86 at PERMANENT type=point
> output=Rast_Temp_Aug_86 column=Rain14
> here Temp_Aug_86 is point vector
> but the problem is solve when we use command like-
> output=Rast_Temp_Aug_86 column=Rain14 labelcolumn=cat
> Regards
> Swapan
> On Sun, Mar 10, 2013 at 2:51 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>> Does this error comes in deleting other maps. Could you try g.copy
>> rast=old,new
>> and delete the newly created raster map.
>> Btw, Please tell your grass version and platform
>> On Sun, Mar 10, 2013 at 1:41 PM, SWAPAN GHOSH <swap.ghsh at gmail.com>wrote:
>>> *Dear all,*
>>> I am using the command like-
>>> Rast_Temp_Aug_86 at PERMANENT is created successfully.
>>> But when I want to delete this raster using command like-
>>> g.remove rast=Rast_Temp_Aug_86 at PERMANENT
>>> Then I get an error like below-
>>> *Removing raster <Rast_Temp_Aug_86 at PERMANENT>
>>> fcell: couldn't be removed*
>>> I am also trying this by running " g.remove -f
>>> rast=Rast_Temp_Aug_86 at PERMANENT " but same problem arises.
>>> Please give me some solution to recover this problem.
>>> *Thanks & Regards,
>>> Swapan*
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Regards,
>>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130311/2374db27/attachment.html>
