[GRASS-dev] Problem deleting raster created from point file using v.to.rast
SWAPAN GHOSH swap.ghsh at gmail.com
Sun Mar 10 23:25:12 PDT 2013
No, I am just creating new raster from point vector map......
 v.to.rast --overwrite input=Temp_Aug_86 at PERMANENT type=point
output=Rast_Temp_Aug_86 column=Rain14
here Temp_Aug_86 is point vector
but the problem is solve when we use command like-
output=Rast_Temp_Aug_86 column=Rain14 labelcolumn=cat
Regards
Swapan
On Sun, Mar 10, 2013 at 2:51 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> Does this error comes in deleting other maps. Could you try g.copy
> rast=old,new
> and delete the newly created raster map.
> Btw, Please tell your grass version and platform
> On Sun, Mar 10, 2013 at 1:41 PM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>> *Dear all,*
>> I am using the command like-
>> Rast_Temp_Aug_86 at PERMANENT is created successfully.
>> But when I want to delete this raster using command like-
>> g.remove rast=Rast_Temp_Aug_86 at PERMANENT
>> Then I get an error like below-
>> *Removing raster <Rast_Temp_Aug_86 at PERMANENT>
>> fcell: couldn't be removed*
>> I am also trying this by running " g.remove -f
>> rast=Rast_Temp_Aug_86 at PERMANENT " but same problem arises.
>> Please give me some solution to recover this problem.
>> *Thanks & Regards,
>> Swapan*
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
>    Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130311/72c2b437/attachment-0001.html>
