[GRASS-dev] Problem deleting raster created from point file using v.to.rast
Rashad M
mohammedrashadkm at gmail.com
Sun Mar 10 01:21:22 PST 2013
Does this error comes in deleting other maps. Could you try g.copy
rast=old,new
and delete the newly created raster map.
Btw, Please tell your grass version and platform
On Sun, Mar 10, 2013 at 1:41 PM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
> *Dear all,*
> I am using the command like-
> v.to.rast --overwrite input=Temp_Aug_86 at PERMANENT type=point
> output=Rast_Temp_Aug_86 column=Rain14
> Rast_Temp_Aug_86 at PERMANENT is created successfully.
> But when I want to delete this raster using command like-
> g.remove rast=Rast_Temp_Aug_86 at PERMANENT
> Then I get an error like below-
> *Removing raster <Rast_Temp_Aug_86 at PERMANENT>
> fcell: couldn't be removed*
> I am also trying this by running " g.remove -f
> rast=Rast_Temp_Aug_86 at PERMANENT " but same problem arises.
> Please give me some solution to recover this problem.
> *Thanks & Regards,
> Swapan*
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130310/bbf59618/attachment.html>
