[GRASS-dev] [GRASS GIS] #2395: Startup runs as in Cygwin when CYGWIN is set although running as native application
GRASS GIS trac at osgeo.org
Wed Aug 20 08:43:02 PDT 2014
application
  Reporter:  wenzeslaus   |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Startup      |     Version:  svn-releasebranch70
Resolution:  fixed        |    Keywords:  cygwin, wingrass, environmetal variables
  Platform:  MSWindows 8  |         Cpu:  Unspecified
Changes (by wenzeslaus):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:9 wenzeslaus]:
 > So, I will change this accoring to [http://lists.osgeo.org/pipermail
 /grass-user/2014-August/070728.html GRASS-user Grass-7.0 beta3 fails to
 launch].
 Committed to trunk and 70 in r61705 and r61706.
 Replying to [comment:11 hellik]:
 > as the source of original failure report is an incomplete installation,
 closing ticket?
 Closing. However, shouldn't the installer tell you that it was in fact
 unsuccessful installation and that nothing will work, or that you are not
 running it with admin rights (assuming now that admin right are really
 necessary). I guess that GRASS itself cannot tell much since it is broken.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:12>
