[GRASS-dev] Backport gunittest and tests to 7.0?
Luca Delucchi
lucadeluge at gmail.com
Tue Nov 11 15:05:32 PST 2014
On 11 November 2014 23:32, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Tue, Nov 11, 2014 at 5:05 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>> I don't understand if gunittest will be backported before 7.0 release,
>> if we backport we can leave that line, otherwise it should be removed
> I also don't know. It is an addition or feature, so it should not (doesn't
> have to) go to release. It is nor really mature either, although it
> apparently runs and works. The distribution is still not solved. Will the
> tests be included in installation? What about compiled C test programs (now
> compiled and added to standard modules)? So far, it has been tested just on
> Ubuntu as far as I know. (More discussion on that should be on GSoC project
> page)
I think we should have a "make test" to run the tests.
I tested it in Debian too
> From the point of view of testing, it would be good to have it in release
> branch as soon as possible, so I don't know.
> Maybe it can go to GRASS GIS 7.0.1 but not to 7.0.0.
+1, so I remove the text from the documentation.
> Vaclav
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
