[GRASS-dev] r.resample.interp also does not behave according to manual
Markus Neteler
neteler at osgeo.org
Sun Aug 30 11:49:35 PDT 2015
On Sun, Aug 30, 2015 at 4:22 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
> Clarification, I'm using a recent build of trunk/GRASS 7.1
> I only want to resample part of a large DEM. I have the region set to the
> appropriate bounds and resolution. And I also have MASK turned on for the
> area to be resampled. Here is an excerpt from the r.resample.interp manual…
> But it give me an error and fails because a line of my input map is outside
> the current region. In fact, most of my input map is outside the current
> region.
Can you please provide a NC dataset example?
thanks
Markus
