[GRASS-dev] Making start of GRASS GIS easier for newcomers
Vaclav Petras
wenzeslaus at gmail.com
Mon Feb 2 18:51:29 PST 2015
On Mon, Feb 2, 2015 at 6:34 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> I think that they are equally as informative and the one on the left
> takes up less space. Just my opinion.
Replacing "Warning: " by nothing in r64407. Other changes included as well,
most notably decreased vertical size at expense of Location and Mapset
lists which are now as big as in 64. The whole dialog is just little bit
bigger than in 64, so with smaller banner it will be hopefully smaller. I
would prefer if it would be possible to make it smaller by dragging but it
is not (I tried several times but I cannot get it work).
I also changed the user visible strings, see commit for details but most
importantly I add numbers to the boxes to make it clear in which order you
should fill them (and that there is an order).
Please, see screenshot (40%), commit message and diff for details.
Vaclav
http://trac.osgeo.org/grass/changeset/64407
> Michael
> On Feb 2, 2015, at 4:11 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Feb 2, 2015 at 5:33 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Mon, Feb 2, 2015 at 11:02 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>> > On Mon, Feb 2, 2015 at 4:50 PM, Michael Barton <Michael.Barton at asu.edu>
>> > wrote:
>> >> Unfortunately the screenshots are too low resolution for me to read
>> them
>> >> here. So I might miss something that is on the screenshot.
>> > It's just about layout, don't worry about text. I can of course send
>> full
>> > size if somebody wants.
>> Please post at least double size...
>> I posted 25%, now posting 50% which is not significantly smaller then
> 100% even after optipng, so I can post just one image at a time.
> Here is what you see when you start 64 for the first time and when you
> start current trunk for the first time.
>> thanks
>> Markus
> <startup_old_and_new_error_warning_50.png>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150202/481f8c42/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150202/481f8c42/attachment-0001.png>
