[GRASS-dev] Making start of GRASS GIS easier for newcomers
Yann Chemin ychemin at gmail.com
Mon Feb 2 19:26:14 PST 2015
It may sound out of place, but would it be possible to call this dialog
anytime during a grass session to manage where you want to work through a
known, unified interface?
On Feb 3, 2015 4:42 AM, "Vaclav Petras" <wenzeslaus at gmail.com> wrote:
> On Mon, Feb 2, 2015 at 6:34 PM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
>>  I think that they are equally as informative and the one on the left
>> takes up less space. Just my opinion.
> Replacing "Warning: " by nothing in r64407. Other changes included as
> well, most notably decreased vertical size at expense of Location and
> Mapset lists which are now as big as in 64. The whole dialog is just little
> bit bigger than in 64, so with smaller banner it will be hopefully smaller.
> I would prefer if it would be possible to make it smaller by dragging but
> it is not (I tried several times but I cannot get it work).
> I also changed the user visible strings, see commit for details but most
> importantly I add numbers to the boxes to make it clear in which order you
> should fill them (and that there is an order).
> Please, see screenshot (40%), commit message and diff for details.
> Vaclav
> http://trac.osgeo.org/grass/changeset/64407
>>  Michael
>>  On Feb 2, 2015, at 4:11 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> On Mon, Feb 2, 2015 at 5:33 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>>  On Mon, Feb 2, 2015 at 11:02 PM, Vaclav Petras <wenzeslaus at gmail.com>
>>> wrote:
>>> > On Mon, Feb 2, 2015 at 4:50 PM, Michael Barton <Michael.Barton at asu.edu
>>> > wrote:
>>> >> Unfortunately the screenshots are too low resolution for me to read
>>> them
>>> >> here. So I might miss something that is on the screenshot.
>>> > It's just about layout, don't worry about text. I can of course send
>>> full
>>> > size if somebody wants.
>>>  Please post at least double size...
>>>  I posted 25%, now posting 50% which is not significantly smaller then
>> 100% even after optipng, so I can post just one image at a time.
>>  Here is what you see when you start 64 for the first time and when you
>> start current trunk for the first time.
>>> thanks
>>> Markus
>>  <startup_old_and_new_error_warning_50.png>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150203/834c85bf/attachment.html>
