[GRASS-dev] Making start of GRASS GIS easier for newcomers
Markus Neteler
neteler at osgeo.org
Fri Jan 30 14:54:15 PST 2015
On Fri, Jan 30, 2015 at 1:35 PM, Yann Chemin <ychemin at gmail.com> wrote:
> Continuing the crazy thoughts,
> You could have FFT/wavelet parameters per column of a raster image
> hard-coded to create an image on request (that I could do I think).
... r.surf.fractal does this... but:
> About a
> vector, well a set of polygon arcs pairs can easily be stored in code and (i
> suppose) imported on the fly as a vector.
... but in times of open data it sounds strange to me to randomly generate data.
You can then not even reproduce the same results. I would definitely
stick to real data as already included in the demolocation.
just my 0.02 cents,
Markus
