[GRASS-dev] [GRASS GIS] #1672: gcpmanager fails to list source mapsets if non-ascii characters in grass data dir path
GRASS GIS trac at osgeo.org
Fri Nov 13 12:09:47 PST 2015
data dir path
  Reporter:  hamish  |      Owner:  grass-dev@…
      Type:  defect  |     Status:  new
  Priority:  normal  |  Milestone:  7.0.2
 Component:  wxGUI   |    Version:  svn-trunk
Resolution:          |   Keywords:  georectifier, UnicodeDecodeError
       CPU:  x86-64  |   Platform:  Linux
Changes (by sebastic):
 * milestone:  6.4.3 => 7.0.2
Comment:
 As reported in [https://bugs.debian.org/676190 Debian Bug #676190], this
 issue is still present in GRASS 7.0.1. When non-ascii characters are in
 the grass data path, the 'Select source mapset:' dropdown is populated
 with empty options. When no non-ascii characters are the path the dropdown
 is populated with the expected mapsets.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1672#comment:3>
