[GRASS-dev] [GRASS-SVN] r66334 - in grass-addons/grass7: . temporal temporal/t.rast.whatcsv temporal/t.rast.whatcsv/testsuite
Sören Gebbert
soerengebbert at googlemail.com
Wed Oct 7 10:05:52 PDT 2015
2015-10-07 17:25 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> On Fri, Sep 25, 2015 at 11:39 AM, <svn_grass at osgeo.org> wrote:
>> Author: neteler
>> New Revision: 66334
>> Added:
>> grass-addons/grass7/temporal/t.rast.whatcsv/t.rast.whatcsv.py
>> Log:
>> t.rast.whatcsv Addon: new prototype module by Soeren Gebbert
>> +from grass.gunittest.gmodules import SimpleModule
>> + r_what = SimpleModule("r.what", map="dummy",
>> + output="-",
>> + separator=separator,
>> + quiet=True)
> Soeren and Markus,
> What is the reason for using SimpleModule from gunittest? In gunittest it is
> used to preset defaults which are needed everywhere in the gunittest. If it
> is advantageous perhaps we should move it to the same place where pygrass's
> Module currently* is. In this case, we need to rethink the defaults and
> naming.
The reason was:
t.rast.whatcsv was a fast hack and i did not take the time to
configure pygrass.modules.Module to do the same as SimpleModule does.
So laziness was the reason.
I think moving SimpleModule to pygrass.modules is a good idea, but
with a better name. Unfortunately i have no better name in mind for
SimpleModule ... .
Best regards
Soeren
> Vaclav
> * I'm saying currently because it seems that we might move it somewhere
> else.
