[GRASS-dev] installing v.mapcalc fails
Vaclav Petras wenzeslaus at gmail.com
Mon Oct 12 18:53:07 PDT 2015
On Mon, Oct 12, 2015 at 6:24 AM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Markus Neteler wrote:
> > <p.vanbreugel at gmail.com> wrote:
> > > Sorry for the late follow up. The add-on installs now. When trying to
run
> > > it, however, nothing happens.
> > It does not have a parser (yet?), so I suppose it reads from stdin.
> Yes.
> But it doesn't have any code to read or write GRASS vectors, either.
> v.mapcalc appears to be a work-in-progress which hasn't actually made
> noticeable progress since it was added.
Then I suggest to remove it from the Makefile parent directory and also
disable it in the addons build scripts if there is something more needed
than r66406 [1] which is blacklisting it somehow already. It does not
fulfill what user would expect (at least some functionality). Those who
want to continue development will get it through svn.
I'm not sure happened [2] with the v.mapcalc implemented as a test case in
GSoC [3] and if the functionality can be still used. But this seems like a
good alternative to the code in addons.
Vaclav
[1] https://trac.osgeo.org/grass/changeset/66406
[2] https://lists.osgeo.org/pipermail/grass-dev/2013-October/065908.html
[3]
https://grasswiki.osgeo.org/wiki/GRASS_GSoC_2013_Temporal_GIS_Algebra_for_raster_and_vector_data_in_GRASS#v.mapcalc
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151012/83379391/attachment.html>
