[GRASS-dev] compiling GRASS fails at configure, unable to locate GDAL library
Markus Neteler
neteler at osgeo.org
Thu Oct 29 04:10:07 PDT 2015
On Thu, Oct 29, 2015 at 12:03 PM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> On 29-10-15 11:38, Markus Neteler wrote:
>> This is not recommended - instead use the GDAL-GRASS plugin to
>> disentangle them properly.
> Thanks Marcus for the feedback. Yes I did compile GDAL with GRASS support,
> mostly because using the GDAL-GRASS plugin has always been problematic,
... indeed it is asking for troubles :)
That's why the plugin was developed.
> something I never have managed to solve, while compiling GDAL with GRASS GIS
> support always have worked without problem for me. But it has been a while I
> tried last, so I will try again, see if it works this time.
Be sure to pick the right version, e.g.
http://download.osgeo.org/gdal/1.11.3/
--> gdal-grass-1.11.3.tar.gz
Markus
