[GRASS-dev] changes in r.in.aster
Carlos Grohmann
carlos.grohmann at gmail.com
Wed Mar 16 09:30:53 PDT 2016
Hi all
After an unsuccessful import of ASTER images, I went looking into the
r.in.aster script and made a few changes that allowed me to import
correctly the images.
OS: Mac OSX El Capitan (with Michael's binary version 7.0.3)
The original issues: The individual bandas were being imported with 15m
resolution for all bands (the region wasn't being re-set for the coarser
resolutions), and all bands imported after 3B had the southern section of
the 3B band (the temp file wasn't being reseted).
My changes:
1 - I changed the band names from 1,2,3b... to 01, 02, 03b... so they are
listed in the right order by the gui (instead of 1, 10, 11,...)
2 - I moved the lines:
tempfile = grass.read_command("g.tempfile", pid = os.getpid()).strip() +
'.tif'
grass.try_remove(tempfile)
to the loop:
if proctype in ["L1A", "L1B"]:
for band in bandlist:
if band in allbands:
so the tempfile is created and destroyed for each band, assuring it is
created according to the band spatial extent and resolution.
3 - This line was giving me errors:
if platform.system() == "Darwin":
cmd = ["arch", "-i386", "gdalwarp", "-t_srs", proj, srcfile,
tempfile ]
arch: posix_spawnp: gdalwarp: Bad CPU type in executable
This is probably because I run OSC El Cap, which is 64bits. So to get it
working, I had to ignore this system test and use
cmd = ["gdalwarp", "-t_srs", proj, srcfile, tempfile ]
Nut I'm not sure what would be the best way to keep the test and maintain
compatibility with older systems. Perhaps a try/except would do.
I attached the modified version.
best
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160316/f3db3d71/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160316/f3db3d71/attachment-0001.obj>
