[GRASS-dev] Interest in GSoC 2016
Rainer M Krug
Rainer at krugs.de
Fri Mar 18 02:52:59 PDT 2016
Pietro <peter.zamb at gmail.com> writes:
> Hi Ondřej,
> On Thu, Mar 17, 2016 at 7:45 PM, <Ondra.Lobo at seznam.cz> wrote:
>> My idea was to generalize GUI Code for Qt-based GUI. Nowadays, Qt (PyQt) is
>> increasingly used (look at QGis, for example) and I think it would be better
>> to have minimally the roots of GUI in Qt. It’s also much easier to maintain
>> with new features. Work with design is also much more user-friendly. It
>> seems that in the future, it can be nice shortcut to change something in the
>> GUI.
> I like the idea, and I think could be strategic for the long run,
> especially because it is not clear to me if and when Phoenix (the
> wxPython for python3) will be ready (and from my superficial
> understanding of the GRASS problem on OS X El Captain Wx it seems part
> of the issue),
With my limited grasp of the grass internals and wxpython:
The main issue For El Capitan is the use of DYNLD_LIBRARY_PATH when
running binaries in /usr/bin or /bin directories (e.g. make). In the
case of homebrew (presumibly Macports as well), during compilation (I
can turn of SIP (System Integrity Progtection) on El Capitan, compile and
install, and enable it again, and it works) and in the case of the
binary compilation and running (as GRASS uses the shell which is in /usr/local/bin).
> instead both pyQt and pySide support python3 (I think
> we should build a GUI compatible with both binding. Consider that
> GRASS is already working with Python3 (with except of the ctype stuff)
> what it is critical (imho) it is the GUI.
> I do like the idea of Vaclav to share a core of functionalities of the
> GUI (between Wx, Qt, Jupyhter, etc). This shared functionalities
> should go in /lib/python/grass/{gui|somethingelse}. This should allow
> us to reduce duplication and the number of code that must be
> maintained.
> I think that we should also consider to split GRASS and its
> functionalities, but I open a separate thread on this.
> Best regards
> Pietro
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160318/869f039d/attachment.sig>
