[GRASS-dev] [GRASS-SVN] r68127 - grass/trunk/lib/gis
Huidae Cho grass4u at gmail.com
Wed Mar 23 21:02:22 PDT 2016
I partly agree with you, but I think at least there should be consistency
in the same file. Those two options had 4 spaces, but others have tabs or 8
spaces. Well, there is still inconsistency... Why don't we use the indent
script for all files?
On Wed, Mar 23, 2016 at 11:52 PM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
> On Wed, Mar 23, 2016 at 11:29 PM, Huidae Cho <grass4u at gmail.com> wrote:
>> Vaclav, that script completely removes tabs and I didn't want to
>> introduce a big revision for no reason other than changing those two
>> options to match the rest of the file.
> I think there is no need to do that. There is a lot of files in the source
> code which do not comply with any (!) version of the indent script. If you
> want the file to be consistent, why not to be consistent with the script
> and actually use it? If inconsistencies with Submitting guidelines are OK,
> why change anything? Perhaps it will turn into the new style itself in time
> if we won't be reverting it back. We can also say that we actually want
> everything to be consistent and do that big change.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160324/2c77282b/attachment-0001.html>
