[GRASS-dev] [SoC]Week-1 WebGrass
Mayank Agrawal mayankagrawal333 at gmail.com
Mon May 30 02:09:15 PDT 2016
Readme-
in the webgrass folder https://github.com/rashadkm/webgrass
mkdir build
cd build
cmake ..
make
sudo ./wgrass.wt --http-address=0.0.0.0 --http-port=8080 --docroot ../
These are the dependencies which will be required beforehand. Install them
one by one.
   1. libwt-dev - C++ library and application server for web applications
   [development]
   2. libwtdbo-dev - Wt::Dbo ORM library for Wt [development]
   3. libwtdbofirebird-dev - Firebird backend for Wt::Dbo [development]
   4. libwtdbomysql-dev - MySQL/MariaDB backend for Wt::Dbo [development]
   5. libwtdbopostgres-dev - PostgreSQL backend for Wt::Dbo [development]
   6. libwtdbosqlite-dev - sqlite3 backend for Wt::Dbo [development]
   7. libwtext-dev - additional widgets for Wt, based on ExtJS 2.0.x
   [development]
   8. libwtfcgi-dev - FastCGI connector library for Wt [development]
   9. libwthttp-dev - HTTP(S) connector library for Wt [development]
   10. libwttest-dev - test connector library for Wt [development]
   11. libpugixml-dev
After this, do let me know with the error.
On Mon, May 30, 2016 at 12:40 PM, Luca Delucchi <lucadeluge at gmail.com>
wrote:
> On 29 May 2016 at 22:29, Mayank Agrawal <mayankagrawal333 at gmail.com>
> wrote:
> > Hi everyone,
> Hi Mayank,
> > I am Mayank Agrawal and I am working on webgrass.
> > my report for the week 1
> > What did you get done this week?
> > The first page of the MainUI of the Grass with all the submenus and
> menus.
> > parsing of the xml file for the menu.
> > restructuring the xml file for better understanding.
> > removing small errors like wrong paths given at different resources,
> routing of the pages
> > see Commits .
> > Results hosted here .
> please use plain text, otherwise during answer we will lost the links
> I tried to compile webgrass but it doesn't work for me, Could you
> extend the README file with dependencies, right now I'm stopped during
> configuration
>  CMAKE_BUILD_TYPE
>  CMAKE_INSTALL_PREFIX             /usr/local
>  Wt_DBOPOSTGRES_DEBUG_LIBRARY     /usr/lib/libwtdbopostgres.so
>  Wt_DBOPOSTGRES_LIBRARY           /usr/lib/libwtdbopostgres.so
>  Wt_DBOSQLITE3_DEBUG_LIBRARY      Wt_DBOSQLITE3_DEBUG_LIBRARY-NOTFOUND
>  Wt_DBOSQLITE3_LIBRARY            Wt_DBOSQLITE3_LIBRARY-NOTFOUND
>  Wt_DBO_DEBUG_LIBRARY             /usr/lib/libwtdbo.so
>  Wt_DBO_LIBRARY                   /usr/lib/libwtdbo.so
>  Wt_DEBUG_LIBRARY                 /usr/lib/libwt.so
>  Wt_EXT_DEBUG_LIBRARY             Wt_EXT_DEBUG_LIBRARY-NOTFOUND
>  Wt_EXT_LIBRARY                   Wt_EXT_LIBRARY-NOTFOUND
>  Wt_FCGI_DEBUG_LIBRARY            Wt_FCGI_DEBUG_LIBRARY-NOTFOUND
>  Wt_FCGI_LIBRARY                  Wt_FCGI_LIBRARY-NOTFOUND
>  Wt_HTTP_DEBUG_LIBRARY            /usr/lib/libwthttp.so
>  Wt_HTTP_LIBRARY                  /usr/lib/libwthttp.so
>  Wt_INCLUDE_DIR                   /usr/include
>  Wt_LIBRARY                       /usr/lib/libwt.so
> > Mayank Agrawal
> > Lab for Spatial Informatics
> > IIIT Hyderabad
> > Hyderabad
> ciao
> Luca
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160530/3213d5a7/attachment.html>
