[GRASS-dev] [SoC]Week-1 WebGrass
Luca Delucchi lucadeluge at gmail.com
Mon May 30 03:14:18 PDT 2016
On 30 May 2016 at 11:09, Mayank Agrawal <mayankagrawal333 at gmail.com> wrote:
> Readme-
> in the webgrass folder https://github.com/rashadkm/webgrass
> mkdir build
> cd build
> cmake ..
> make
> sudo ./wgrass.wt --http-address=0.0.0.0 --http-port=8080 --docroot ../
I read it already, but it was not enough
> These are the dependencies which will be required beforehand. Install them one by one.
> libwt-dev - C++ library and application server for web applications [development]
> libwtdbo-dev - Wt::Dbo ORM library for Wt [development]
> libwtdbofirebird-dev - Firebird backend for Wt::Dbo [development]
> libwtdbomysql-dev - MySQL/MariaDB backend for Wt::Dbo [development]
> libwtdbopostgres-dev - PostgreSQL backend for Wt::Dbo [development]
> libwtdbosqlite-dev - sqlite3 backend for Wt::Dbo [development]
> libwtext-dev - additional widgets for Wt, based on ExtJS 2.0.x [development]
> libwtfcgi-dev - FastCGI connector library for Wt [development]
> libwthttp-dev - HTTP(S) connector library for Wt [development]
> libwttest-dev - test connector library for Wt [development]
> libpugixml-dev
please add this in the readme file
> After this, do let me know with the error.
no error, now I'm able to run it but I cannot modify the grassdata
directory, is it normal?
ciao
Luca
www.lucadelu.org
