[GRASS-dev] PO file breakage in trunk and 7.2 branch
Maris Nartiss maris.gis at gmail.com
Mon Nov 14 05:39:08 PST 2016
It failed to generate MO files due to duplicate MSGID's. The bad thing
is that make process finishes without error, although halfway make po
has died with a fatal error.
Just check your compiled version locale/blabla/blabla.mo files. There
should be three of them for each language. On my system it generated
just one as make po failed without notification at the end of
compilation.
+1 for exclude fix.
Māris.
2016-11-14 15:26 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> Hi Maris,
> On Mon, Nov 14, 2016 at 2:17 PM, Maris Nartiss <maris.gis at gmail.com> wrote:
>> Hello Markus,
>> unfortunately your commit r69811 breaks PO file compilation in trunk.
> strange, I recompiled twice using "make distclean" and no issues happened.
> What was really broken?
>> When fixing typos, PO files should not be touched directly but just
>> updated from the fixed source files (make pot && make update-po).
> It depends. Single words can be certainly fixed if done both in source
> code and po files.
> Probably I missed to fix a typo elsewhere in the source code? (would
> need the error message to know since it didn't happen here).
>> I took the liberty to revert changes to PO files and update them to
>> include fixed spelling, still fix_typos script should be updated to
>> exclude locale/po directory.
> That I already added yesterday:
> EXCLUDED_FILES="$EXCLUDED_FILES,*/locale/po/*.po"
>> Wops! I see that the change was backported to 7.2 as r69812! The same
>> "dance" must be performed there (cd locale/po && svn up -r 69812:69811
>> && svn ci && cd .. && make pot && make update-po && svn ci).
> I have compiled on the 3rd machine right now and no issue appeared.
> However, I'll redo the po files.
> Markus
