[GRASS-dev] grass wiki: de-emphasize grass6
Paulo van Breugel
p.vanbreugel at gmail.com
Sat Aug 12 02:34:51 PDT 2017
On 8/12/17 5:03 AM, Vaclav Petras wrote:
> Paulo,
> thanks so much for a needed update.
> On Fri, Aug 11, 2017 at 8:51 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> I kept the link to
> https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7
> <https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7> but what
> about merging it with R_statistics? If we do, can keep
> https://grasswiki.osgeo.org/wiki/R_statistics/spgrass6
> <https://grasswiki.osgeo.org/wiki/R_statistics/spgrass6> as a page
> to go for grass6 users.
> I'm not in favor of the subpage idea for user wiki (but I think others
> are), so I'm for merging it or creating a special page if it is
> important to highlight separately from the general idea.
+1
> (Does R+GRASS == rgrass? Or is also RQGIS?)
I would limit this to R+GRASS. RQGIS is a whole different story.
> In this case, it seems that overview page is needed and then a
> specific page. rgrass7 is quite long already.
Merging it with r_statistics wouldn't make it that much longer, most
what is on the r_statistics page is also on rgrass7 page. We can move
the introduction on r_statistics to rgrass7, see if there is anything
else worth moving, and that's it I think (about the name of such page,
see below).
> When you are at it, also note that the wiki page name is "R
> statistics" which is not the name of the project, nor the way how the
> project refers to itself [1]:
> What is R?
> R is a language and environment for statistical computing and graphics.
> The R environment
> R is an integrated suiteĀ of software facilities for data manipulation,
> calculation and graphical display.
> => "R statistical environment" or Wikipedia's "R (programming
> language)" if you want to avoid just "R".
One reason to use R<-->GRASS is that R adds statistical capabilities to
GRASS. I guess this is why the pages was called R_statistics? But there
are more possible reasons to use the two together. So, given that the
page (and the rgrass7 page) is about using GRASS and R in conjunction,
we could use the name 'GRASS-R', or more verbose, 'Using R with GRASS',
or if possible in the url, 'GRASS<-->R'
> Vaclav
> [1] https://www.r-project.org/about.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170812/b34acb50/attachment-0001.html>
