[GRASS-dev] ** (wxgui.py:19192): WARNING **: invalid source position for vertical gradient
Anna Petrášová kratochanna at gmail.com
Wed Sep 20 07:44:07 PDT 2017
On Wed, Sep 20, 2017 at 10:39 AM, Vincent Bain <bain at toraval.fr> wrote:
> looks like this problem appeared some time ago :
> https://lists.osgeo.org/pipermail/grass-user/2016-August/074641.html
> As Robert asked, is there a way to set, at least temporarily, the
> verbosity of these messages ?
not easily I think, maybe if you recompile some of the underlying
libraries and set somehow their verbosity, it would be theoretically
possible, but I didn't investigate that option.
> V.
> Le mercredi 20 septembre 2017 à 15:44 +0200, Vincent Bain a écrit :
>> wxPython: 3.0.2.0
>> My old debian 8.8 install has wxPython: 3.0.1.1
>> On another hand, trying to find out what was new between debian 9.0 and
>> debian 8.8 configurations, I noticed there was a difference concerning
>> wx-config alternatives:
>>         - in the former it pointed towards
>>         /usr/lib/i386-linux-gnu/wx/config/base-unicode-3.0
>>         - while in the newer it points toward
>>         /usr/lib/i386-linux-gnu/wx/config/gtk2-unicode-3.0
>> I tried to rebuild (after a distclean) with the previous configuration,
>> i.e. base-unicode-3.0
>>         $ update-alternatives --config wx-config
>> but the error still rises.
>> Perhaps I should try to revert to wxPython 3.0.1.1
>> Vincent.
>> Le mercredi 20 septembre 2017 à 15:23 +0200, Markus Neteler a écrit :
>> > On Wed, Sep 20, 2017 at 2:01 PM, Vincent Bain <bain at toraval.fr> wrote:
>> > > after digging it a little bit deeper, I guess it has rather something to
>> > > do with the environment : I currently work on different debian machines;
>> > > the issue happens when I build the latest trunk version (r:71500) on a
>> > > new/clean debian 9 (stretch). Building the same release on my old debian
>> > > 8 works fine.
>> > Please check the wxPython version, through g.gui > Help > About system
>> > Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
