[GRASS-dev] ** (wxgui.py:19192): WARNING **: invalid source position for vertical gradient
Vincent Bain bain at toraval.fr
Wed Sep 20 07:59:18 PDT 2017
Well,
thanks Anna and Markus for you interest.
It might not be specifically a GRASS issue. Changing the gtk+ theme
engine of my desktop from Adwaita to Clearlooks solved the problem in
one go, no more warnings... did not look attentively but it seems
adwaita was the only problematic theme (I mean among those installed
down here).
Hope this instant of serendipity can help you find a cure to this buggy
behavior !
Yours,
Vincent.
Le mercredi 20 septembre 2017 à 10:44 -0400, Anna Petrášová a écrit :
> On Wed, Sep 20, 2017 at 10:39 AM, Vincent Bain <bain at toraval.fr> wrote:
> > looks like this problem appeared some time ago :
> > https://lists.osgeo.org/pipermail/grass-user/2016-August/074641.html
> > As Robert asked, is there a way to set, at least temporarily, the
> > verbosity of these messages ?
> not easily I think, maybe if you recompile some of the underlying
> libraries and set somehow their verbosity, it would be theoretically
> possible, but I didn't investigate that option.
> > V.
> > Le mercredi 20 septembre 2017 à 15:44 +0200, Vincent Bain a écrit :
> >> wxPython: 3.0.2.0
> >> My old debian 8.8 install has wxPython: 3.0.1.1
> >> On another hand, trying to find out what was new between debian 9.0 and
> >> debian 8.8 configurations, I noticed there was a difference concerning
> >> wx-config alternatives:
> >>         - in the former it pointed towards
> >>         /usr/lib/i386-linux-gnu/wx/config/base-unicode-3.0
> >>         - while in the newer it points toward
> >>         /usr/lib/i386-linux-gnu/wx/config/gtk2-unicode-3.0
> >> I tried to rebuild (after a distclean) with the previous configuration,
> >> i.e. base-unicode-3.0
> >>         $ update-alternatives --config wx-config
> >> but the error still rises.
> >> Perhaps I should try to revert to wxPython 3.0.1.1
> >> Vincent.
> >> Le mercredi 20 septembre 2017 à 15:23 +0200, Markus Neteler a écrit :
> >> > On Wed, Sep 20, 2017 at 2:01 PM, Vincent Bain <bain at toraval.fr> wrote:
> >> > > after digging it a little bit deeper, I guess it has rather something to
> >> > > do with the environment : I currently work on different debian machines;
> >> > > the issue happens when I build the latest trunk version (r:71500) on a
> >> > > new/clean debian 9 (stretch). Building the same release on my old debian
> >> > > 8 works fine.
> >> > Please check the wxPython version, through g.gui > Help > About system
> >> > Markus
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/grass-dev
