[GRASS-dev] r.in.pdal
Vaclav Petras wenzeslaus at gmail.com
Tue Aug 7 18:57:14 PDT 2018
Hi Anika,
I'm glad to finally see this module; now I'm testing it. Please review the
code and the submission guidelines. Basically it boils down to "use pep8
tool." See the following for details.
https://trac.osgeo.org/grass/wiki/Submitting/Python#Style
To improve it even more, you can use lower_case_with_underscores (aka
snake_case) instead of CamelCase/camelCase for variables and functions.
Thank you,
Vaclav
On Mon, Aug 6, 2018 at 6:50 AM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> 2018-08-06 12:12 GMT+02:00 Anika Bettge <bettge at mundialis.de>:
> > Hi all,
> > I just uploaded my first GRASS GIS addon r.in.pdal:
> > https://trac.osgeo.org/grass/browser/grass-addons/grass7/
> raster/r.in.pdal.
> Thanks a lot to your contribution Anika!
> A few cosmetic suggestions:
> the print command in L268 should be replaced with grass.message because
> this is not shell-style output
> L353:
>         grass.message(_("Generating output raster map <%s>...") % outfile)
> seems to be at the wrong place because nothing happens after that message
> same for L191
> you can you set the metadata on the resultant output raster with
> r.support, otherwise metadata will be set by r.in.xyz (the module that
> actually created the raster)
> there are some comments on gdalwarp, but gdalwarp is not used by r.in.pdal
> Best,
> Markus M
> > Best regards,
> > Anika
> >   Anika Bettge
> >   - Anwendungsentwicklerin -
> >   mundialis GmbH & Co. KG
> >   Kölnstraße 99
> >   53111 Bonn
> >   Tel: +49 (0)228 / 38 75 80 -80
> >   Fax: +49 (0)228 / 96 28 99 -57
> >   Email: bettge at mundialis.de
> >   Web: https://www.mundialis.de
> >   Amtsgericht Bonn, HRA 8528
> >   Komplementärin: mundialis Verwaltungsgesellschaft mbH
> >   vertreten durch: Dr. Markus Neteler, Hinrich Paulsen, Till Adams
> >   Informationen über Ihre gespeicherten Daten finden Sie auf unserer
> Homepage unter folgendem Link:
> >   https://www.mundialis.de/datenschutzerklaerung
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180807/2ce21bd8/attachment.html>
