[GRASS-dev] Installing non-standard Python addons in winGRASS
Michel Wortmann wortmann at pik-potsdam.de
Mon Jun 18 02:19:40 PDT 2018
Hi Vaclav,
I can give it a try but I don’t actually work on Windows myself, i.e. testing and developing this would be a bit cumbersome. If you are ok with testing it and fully implementing it in g.extension, then that would be great.
Regards,
Michel
> On 15. Jun 2018, at 16:48, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Fri, Jun 15, 2018 at 6:55 AM, Michel Wortmann <wortmann at pik-potsdam.de <mailto:wortmann at pik-potsdam.de>> wrote:
> Any help would be greatly appreciated. I would also volunteer to test/add a Python script installation function to g.extension, as hinted on in the man page.
> For me, the preferred solution is to add that functionality to g.extension, i.e. re-implement the make/Makefile functionality in Python and then switch to that on MS Win (with a flag to do the same on other systems too). If you already have some code or you are willing to take a shot at this, please go ahead and open a ticket and submit a patch.
> Best,
> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180618/217744b3/attachment-0001.html>
