[GRASS-dev] Strange behavour of t.register command
Sören Gebbert
soerengebbert at googlemail.com
Thu May 10 02:22:58 PDT 2018
the second command is the correct one, since the "unit" option in the
first command should only be used in case of "relative" time in an
STRDS.
You have to make sure that the "time_dataset" was created with the
correct temporal type, which in your case is "absolute "time.
Best regards
Sören
2018-05-10 11:05 GMT+02:00 Roberto Marzocchi <roberto.marzocchi at gmail.com>:
> Dear lists,
> we are testing the command t.register
> t.register --o --q -i maps=(name of maps separated by comma)
> input=time_dataset start='2011-11-03 02:00:00' increment='120'
> unit='minutes'
> it run without error but when running g.gui.animation or g.gui.tplot using
> the time series dataset I have the following error: Topology of Space time
> dataset time_dataset at mapset is invalid.
> I tried the following command (reading the manual of t.register)
> input=time_dataset start='2011-11-03 02:00:00' increment='120 minutes'
> and
> - one PC I read the following error ERRORE: invalid literal for int() with
> base 10: '00+00'
> - on PC run correctly and I can run the gui commands witout any error
> I have the same GRASS package installed on both the PC (7.4.0-1~xenial1)
> R
