[GRASS-dev] [GRASS-SVN] r73692 - grass/trunk/lib/init
Markus Metz markus.metz.giswork at gmail.com
Sun Nov 25 07:31:05 PST 2018
On Sun, Nov 25, 2018 at 4:06 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Sat, Nov 24, 2018 at 9:58 PM Vaclav Petras <wenzeslaus at gmail.com>
wrote:
>> On Sat, Nov 24, 2018 at 5:54 AM Markus Metz <
markus.metz.giswork at gmail.com> wrote:
>>> On Thu, Nov 22, 2018 at 11:33 PM Vaclav Petras <wenzeslaus at gmail.com>
wrote:
>>> > That's all correct. There would have to be more to make it the same
procedure as in grass.py, but eventually we need to do that.
>>> > What I meant to add it to grass.script.setup module where we should
eventually put all the functions needed to setup a proper GRASS session (or
in some other module, but setup seems to be something good enough for now
and moving things around while keeping the API is easy in Python).
>>> ok, the db cleanup is now (r73704) a function in grass.script.setup
>> Great! Thanks. I tried to clean grass.py as much as possible, so I hope
it's possible to make changes there.
> Unfortunately, just running:
> $ grass77 --tmp-location XY --exec g.region -p
> Execution of <g.region -p> finished.
> Traceback (most recent call last):
>   File "./bin.x86_64-pc-linux-gnu/grass77", line 2260, in <module>
>     main()
>   File "./bin.x86_64-pc-linux-gnu/grass77", line 2208, in main
>     clean_all(params.tmp_location)
> TypeError: clean_all() takes no arguments (1 given)
oops, fixed in r73708
Markus M
> $ svnversion
> 73707M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181125/84a6fbae/attachment-0001.html>
