[GRASS-dev] v.clip and latlon?
Vaclav Petras
wenzeslaus at gmail.com
Sun Nov 25 18:12:45 PST 2018
On Sun, Nov 25, 2018 at 6:16 PM Michael Barton <Michael.Barton at asu.edu>
wrote:
> Can do. Wanted to check first so as not to duplicate anything (search in
> Trak leaves much to be desired).
I agree, but mostly because there is this hard split between full text
search and query. The is no "fuzz search" so when somebody just misspells
the name of the module, then there is no help. Other than that, I'm usually
quite successful in finding things with one or the other (the trick for the
full text search is to leave checked only the type(s) you really need).
> I might first try it on a vector from the NC demo data to make sure that
> it works there (or not).
Sounds good! Thanks.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181125/102a2256/attachment.html>
