[GRASS-dev] Unable to install manual for add-on r.estimap.recreation under Windows
Nikos Alexandris
nik at nikosalexandris.net
Sun Jan 13 10:42:40 PST 2019
* Nikos Alexandris <nik at nikosalexandris.net> [2019-01-13 19:26:04 +0100]:
>* Helmut Kudrnovsky <hellik at web.de> [2019-01-13 09:51:25 -0700]:
>>NikosAlexandris wrote
>>>Dear Windows experts,
>>>in installing the add-on r.estimap.recreation under Windows, I get this
>>>error:
>>>ERROR: Unable to read manual page: [Errno 2] No such file or directory:
>>>'C:\\OSGEO4~1\\apps\\grass\\grass-7.4.4\\docs\\html\\r.estimap.recreation.html'
>>>What can I do about this? Is it an non-clean installation of GRASS GIS
>>>issue?
>>>I've found a couple of old references:
>>>https://lists.osgeo.org/pipermail/grass-dev/2012-November/060651.html
>>>https://lists.osgeo.org/pipermail/grass-user/attachments/20141023/007284ec/attachment.html
>>>https://lists.osgeo.org/pipermail/grass-dev/2015-August/075990.html
>>>Nothing with a specific explanation and solution though.
>>>Nikos
>>>_______________________________________________
>>>grass-dev mailing list
>>>grass-dev at .osgeo
>>>https://lists.osgeo.org/mailman/listinfo/grass-dev
>>see compilation Log:
>>https://wingrass.fsv.cvut.cz/grass77/x86_64/addons/grass-7.7.svn/logs/r.estimap.recreation.log
>>the addon isn't compiled, therefore the Message.
>Thanks for heads-up! Now, what's next to check?
>if [ "/c/Users/landa/grass_packager/grass77/x86_64/addons/r.estimap.recreation/scripts/r.estimap.recreation.py" != "" ] ; then GISRC=/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/demolocation/.grassrc77 GISBASE=C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32 PATH="/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/scripts:$PATH" PYTHONPATH="C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/etc/python;C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/gui/wxpython;$PYTHONPATH" PATH="/c/Users/landa/grass_packager/grass77/x86_64/addons/r.estimap.recreation/bin:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/scripts:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/lib:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/lib:/c/osgeo4w64/bin:/c/msys64/usr/bin:/c/msys64/mingw64/bin:/c/ProgramData/Oracle/Java/javapath:/c/Windows/system32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0:/c/Program Files/Microsoft SQL Server/110/Tools/Binn:/c/Program Files/Microsoft Windows Performance Toolkit:/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit:/c/Program Files (x86)/Git/cmd" LC_ALL=C LANG=C LANGUAGE=C /c/Users/landa/grass_packager/grass77/x86_64/addons/r.estimap.recreation/scripts/r.estimap.recreation.py --html-description < /dev/null | grep -v '</body>\|</html>' > r.estimap.recreation.tmp.html ; fi
>/bin/sh: /c/Users/landa/grass_packager/grass77/x86_64/addons/r.estimap.recreation/scripts/r.estimap.recreation.py: /usr/bin/python: bad interpreter: Permission denied
>/c/msys64/usr/src/grass_trunk/include/Make/Html.make:14: recipe for target 'r.estimap.recreation.tmp.html' failed
>What can I make out of this? Is there something wrong in the HTML file?
>(Which I need to update, anyway.) I am searching of course in trac and
>else to see how I can go on with this.
Is it the shebang line? I.e., it should be
`#!/usr/bin/env python`
instead of
`#!/usr/bin/python` ?
I have to wait till tomorrow for the re-compilation I guess.
Nikos
