[GRASS-dev] winGRASS addons - consolidation/fix release needed!!
Helmut Kudrnovsky hellik at web.de
Sat Jul 27 13:59:51 PDT 2019
hi,
actually, there are several complaints that downloading precompiled winGRASS
addons isn't working, see e.g.
https://trac.osgeo.org/grass/ticket/3455#comment:5
https://lists.osgeo.org/pipermail/grass-web/2019-July/004925.html
https://lists.osgeo.org/pipermail/grass-user/2019-July/080557.html
etc.
checked now the situation of download server URLs and related g.extension
code lines regarding several branches and master:
*grass72
https://wingrass.fsv.cvut.cz/grass72/x86/addons/
[DIR]	grass-7.2.2/	2019-07-07 09:10 	-
[DIR]	grass-7.2.3/	2019-07-07 09:10 	-
[DIR]	latest/	2019-07-07 09:10 	-
https://wingrass.fsv.cvut.cz/grass72/x86_64/addons/
*grass74
https://wingrass.fsv.cvut.cz/grass74/x86_64/addons/
[DIR]	grass-7.4.svn/	2019-07-25 09:06 	-
https://github.com/OSGeo/grass/blob/releasebranch_7_4/scripts/g.extension/g.extension.py#L937
    base_url = "http://wingrass.fsv.cvut.cz/" \
               "grass%(major)s%(minor)s/%(platform)s/addons/" \
               "grass-%(major)s.%(minor)s.%(patch)s" % \
               {'platform': platform,
                'major': version[0], 'minor': version[1],
                'patch': version[2]}
*grass76
https://wingrass.fsv.cvut.cz/grass76/x86_64/addons/
[DIR]	grass-7.6.svn/	2019-07-25 09:06 	-
[DIR]	latest/	2019-07-25 09:06 	-
https://wingrass.fsv.cvut.cz/grass76/latest/addons/
https://github.com/OSGeo/grass/blob/releasebranch_7_6/scripts/g.extension/g.extension.py#L937
*grass77
https://wingrass.fsv.cvut.cz/grass77/x86_64/addons/
[DIR]	grass-7.7.dev/	2019-07-25 09:06 	-
https://github.com/OSGeo/grass/blob/master/scripts/g.extension/g.extension.py#L1021
in the MLs there are some suggestions for workarounds, e.g.
in https://trac.osgeo.org/grass/ticket/3455#comment:6
following change is suggested:
                #'patch': version[2]}
                'patch': 'svn'}
the same in
https://lists.osgeo.org/pipermail/grass-user/2019-July/080526.html
            #'patch': version[2]} # comment this out
            'patch': 'svn'} # add this
see e.g.
https://lists.osgeo.org/pipermail/grass-user/2019-July/080561.html
shows that, with the workaround, a GRASS GIS library mismatch issue may
occur.
* for the short term, we need a winGRASS addon consolidation and a fix
release; our winGRASS users seem to use the addons in a regular way
* for the long term, buidling winGRASS addon via appveyor (compare e.g.
https://pdal.io/development/compilation/windows.html) may be another way to
deliver them.
in another thread a discussion started how GRASS GIS should handle addons
after the GIT switch: central repo vs. distributed addon repos.
short and long term ideas/solutions for winGRASS addons mentioned above are
related to the question central repo vs. distributed addon repos.
ideas? suggestions? PRs?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
