[GRASS-dev] svn/trac -> git/github migration plan
Panagiotis Mavrogiorgos pmav99 at gmail.com
Sat May 18 08:59:17 PDT 2019
hello Markus,
I would suggest that:
- even core devs fork the main repo
- "origin" is the personal remote GRASS repository (e.g. in my case
https://github.com/pmav99/grass)
- everyone adds the main GRASS repository as a secondary remote (e.g.
"upstream")
This way:
1. You always push to "origin" and you create a Pull Request from the
Github UI
2. To get updates you always pull from "upstream"
3. You always rebase your code to "upstream/master".
4. You don't need separate instructions for non core-devs.
Just my 2 cents.
P.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190518/323b35e1/attachment.html>
